testing a electric widow motor?
Old Dec 2, 2009 | 06:09 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
I picked up a drivers side door on craiglist... really nice condition with a window for $35.
The window is UP about 75%, and I'd like to be able to lower it ,and at the same time test the motor. I tried running a 12V positive wire to the borwn wire,and the negative to the blue one with the white stripe. Nothing happened, and then I reversed it.
Shouldn't one of those make the window go either up or down? I got the power lock to click over using that method
Old Dec 2, 2009 | 06:36 PM
58mark's Avatar
Re: testing a electric widow motor?
crap. I just found my service manual wiring diagram. It looks like the ground is based off of the switch, so i would have to have an extra switch to run the window up and down.
Let me know if you know a way around this
Old Dec 2, 2009 | 11:07 PM
conlinj's Avatar
I use a pigtail i cut off a spare harness and a dewalt battery to raise and lower mine. Should work the way you did it, maybe the motor is bad.
-Jim
BRoss99
Aug 10, 2025 05:08 PM
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Mickeyruder
Sep 2, 2015 02:45 PM
TheExaminer
Aug 19, 2015 10:07 PM
