Lower Power Usage?
Old Dec 12, 2009 | 03:20 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Lower Power Usage?
When i run at idle its about 14.3 which it should be but when lights are on at night and and speakers are on.. i run about 13. Engaging my turn signal and everytime it flashes raises the rpms about 50, i see the needle bounce.. I was wondering if there are other alternatives for my vehicle for lights to be used that would use much less power? I did my gauge lights and interior lights to be led...
any ideas?
Old Dec 14, 2009 | 10:01 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Use Candles
Your voltmeter might not be accurate.
You can use a test meter to verify.
The RPM variation might be due to IR drop, or a poor connection to or in the dash.
But you said at idle, if the problem goes away when you hit the loud pedal don’t worry about it.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Old Dec 14, 2009 | 01:37 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Lower Power Usage?
ok, i just wanted to make sure... thats all
Azrael91966669
25
Jun 20, 2017 04:04 AM
deracer
Apr 11, 2016 12:04 AM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
