91 camaro rs T5 Speedometer wrong
Old Dec 15, 2009 | 12:54 PM
Ninety-One's Avatar
Car: 91 LT1 RS 89 IROC-Z 350 TPI
Engine: LT1 // 350 TPI
Transmission: WC T5 // 700R4
Axle/Gears: BW 9 Bolt 3.27 //BW 9 Bolt 2.77
Need help fixing off speedometer. Couldn't find a cable, (assuming it's electric?) But I upgraded to 3.73 gears and need help on how to set the speedometer to the proper speeds. Stock tires and wheels, T5 trans.
Any help appreciated!
Old Dec 15, 2009 | 02:54 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: 91 camaro rs T5 Speedometer wrong
Well what you need to do fortunately isnt too bad all you need to do is replace the speedometer drive gear to match your new rear gears.
Old Dec 15, 2009 | 06:17 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You need to replace the drive and/or driven gears depending on what the previous gears were: 3.08 down you'll need to replace both, 3.23 up the driven gear.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
Elephantismo
Feb 13, 2019 12:51 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
