Need help locating Blower Switch, Blower Resistors, and Blower Relay
Old Dec 18, 2009 | 11:22 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Can anyone help me out here, please? Im going to install my heating system but the blower doesnt turn on. Heater A/C fuse is good but no dice. Any info. helps. Thanks.
Attached Thumbnails Need help locating Blower Switch, Blower Resistors, and Blower Relay-blower-diagram.jpg
Old Dec 19, 2009 | 07:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Need help locating Blower Switch, Blower Resistors, and Blower Relay
The HAVC switch/control is inside the car above the radio.
Note the following post #4 in the following link:
https://www.thirdgen.org/forums/elec...aro-rs-no.html
The resistor connector, at the top of the pic, is gray with purple, blue, etc.
IIRC, the relay is down a bit and off to the right.
JamesC
Old Dec 19, 2009 | 06:35 PM
Pocket's Avatar
Car: 91 Trans Am
https://www.thirdgen.org/forums/elec...lp-needed.html
Last post has several pics of the connectors you're looking at. A good fuse and no fan means something isnt getting power
Unplug the relay and test for 12v constant at the red wire. No power means blown fusible link. Those are on the starter lug
If you've got power then its a dead relay or a bad ground from the fan
Old Dec 19, 2009 | 06:52 PM
Ok. Thanks for the help guys, Pocket- Im going to test out that relay to see if there is power. Agian, thanks guys
Old Apr 6, 2019 | 02:07 PM
91ls1t56's Avatar
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
Sorry, posted in wrong thread.
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
soarestransam
Sep 1, 2015 04:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
