PUSH IN CLUTCH AND STARTER TURNS?
Old Dec 24, 2009 | 12:15 AM
KRACKER JACK's Avatar
Car: CAMARO RS
Engine: 3.1 V6,5.0 tpi
Transmission: AUTOMATIC, t5
Axle/Gears: one tire fire ,posi disc
i swaped a dash in to my car and when i push in the clutch the starter turns any ideas thanks
Old Dec 24, 2009 | 12:16 AM
Car: CAMARO RS
Re: PUSH IN CLUTCH AND STARTER TURNS?
it isnt a 4th gen dash either its just a 90 firebird formula dash
Old Dec 24, 2009 | 01:22 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The starter inhibitor switch on the clutch prevents you starting in gear; it lets you start when you have the clutch down ( switch closes)
Obviously you have a fulltime hot wire (wrong ) direct to the starter solenoid circuit so the clutch switch is now acting as a starter switch
Old Dec 24, 2009 | 03:36 PM
HankL69's Avatar
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
My guess would be the ignition switch is shorted some how or the wires to the switch are crossed somewhere. As stated above the switch on the clutch pedal is doing what it is supposed to do. Good luck.
Old Dec 24, 2009 | 06:16 PM
Car: CAMARO RS
i just rewierd the switch now it works right thanks
Derick15
Sep 17, 2016 05:28 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
