Need help with high beams not working
Old Dec 29, 2009 | 08:04 PM
92Firebirdman's Avatar
The high beams on my '92 trans am aren't working... I'll pull back on the turn signal switch, and get nothing. The low beams work fine... How do I fix this problem?
Old Dec 29, 2009 | 08:26 PM
JJx91camaro's Avatar
Car: 1991 chevy camaro rs
Engine: carbed 350 sbc
Transmission: th350
Re: Need help with high beams not working
check to see if the linkage is all connected properly to the switch on the steering column, i had this problem and all i had to do was adjust the linkage a little bit
Old Dec 29, 2009 | 08:27 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If the wheel is tilt - try the turn signal lever at different positions on the tilt. Mine works when the wheel is tilted all the way down, but won't always work when I have the wheel adjusted for driving.
There is a rod that runs down the length of the steering column and pushes a button on a switch that is just above the brake pedal - alot of times the switch needs readjusted - there are 2 7mm screws that hold it in place - loosen those and move the switch very slightly up the steering column, retighten, and see if it helps.
Old Dec 29, 2009 | 08:44 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Or the switch itself may have gone south.
JamesC
Old Jan 3, 2010 | 06:51 PM
chrisstock's Avatar
i have the same problem and i tore apart the covers and a plastic part fell out when the cover was removed and there is nothing touching the rod for the high beams, i dont know how this part goes on or if its the problem, help?
Old Jan 3, 2010 | 07:03 PM
Drew's Avatar
My Formula had a bit of play in the steering wheel, and pulling the lever only worked about 10% of the time. The pivot pins in the tilt column had backed out. Once they were pressed back in the high beams worked perfect again.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fronzizzle
Aug 19, 2015 01:36 PM
jackhammer
Aug 15, 2015 10:04 PM
BBSDesigns
Aug 11, 2015 07:39 PM
