Ignition module
Old Jan 5, 2010 | 01:39 PM
carbsrule's Avatar
Car: 1996 jeep cherokee
Engine: 4.0
Transmission: 4 speed auto
Axle/Gears: chrysler 8 3/4 3.08 gears
Ignition module
Looking into buying a 1987 camaro with a carbed 350. Its got the electronicly controled quadrajet. I plan on buying it regardless because the guy wants $100 for it, the reason its so cheap is because it keeps popping ignition modules. What could cause this? Heat, overworking? any help is appreciated.
Old Jan 5, 2010 | 02:09 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Ignition module
Is the ignition module in the distributor? If so, Failure to apply silicone grease to the underside of the dizzy will result in ignition module failure due to heat.
Good luck
Old Jan 5, 2010 | 02:22 PM
carbsrule's Avatar
Engine: 4.0
Re: Ignition module
underside? like where? between the module and dizzy?
Old Jan 5, 2010 | 02:34 PM
Drew's Avatar
Re: Ignition module
Exactly. The ignition module has a bare metal pad on the bottom side, it needs the grease to help conduct heat to the base of the distributor as a heat sink. But, it probably wouldn't die right away from heat.
Old Jan 5, 2010 | 02:45 PM
carbsrule's Avatar
Engine: 4.0
Re: Ignition module
I just talked to the guy who i am buying it from. He has tried that. Im thinking of just putting a points dizzy in it with a pertronix. Would this solve the problem?
Old Jan 5, 2010 | 02:54 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Foiled Coil
Your coil is shorting internally under load.
Replace it B4 you install a new module.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
Old Jan 5, 2010 | 03:12 PM
carbsrule's Avatar
Engine: 4.0
Re: Ignition module
Thanks. I will look into it. The guy who owns it is giving it to a buddy of mine. He wants to save some money by not feuling up his f150 5 times a month so i am trading him for my 1986 murcury lynx. He is going to buy the coil and ignition module and register the car for me to equal out what i paid for the car and the money i put into it.
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
