how important are spike suppression relays?
Old Jan 10, 2010 | 11:01 AM
dirtpoor1's Avatar
Car: 84 z28
Engine: 305 vin H
Transmission: auto
Need to install a couple of relays for dome light and rear hatch release for use with my new keyless entry system. Some relays have built in resistors for voltage spike suppression which is suppose to help prevent damage to the electrical components some do not. Just how important is the suppression resistor? I already have a bosh relay without resistor, shoulld I use it or get two with resistors? Just wondering how critical the resistor is or if it's a lot of hype. thanks.
Old Jan 10, 2010 | 01:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: how important are spike suppression relays?
They're diodes, not resistors. You can easily add one to the circuit of a relay that doesn't have it already.
Old Jan 11, 2010 | 11:50 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Suppression Suggestion
Re diodes.
You need to observe polarity.
Diodes have a line on them.
The line must be toward the positive.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
Old Jan 11, 2010 | 12:27 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
There pretty important actually. What happens is any thing with a coil (basically an inductor) will attempt to maintain the same amount of current through it regardless of the change in voltage across it. So when you de energize a coil like in a relay the collapsing magnetic field induces a voltage in itself in an attempt to maintain the same current through it (sounds kinda familiar dosnt it? Like how an ignitions system works perhaps? lol). Because its an open circuit that voltage spike is pretty large. This large voltage spike can exceed the voltage specs and damage things (kinda like how static shocks can damage chips). To control this as stated they use diodes (or diode resistor combinations) to in essence short out these voltage spikes. How important is it in your situation? Depends what its hooked up to but adding a properly sized diode cannot hurt only help.
Linson
Oct 24, 2025 02:00 PM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Linson
Oct 1, 2015 09:50 PM
