Tach acting strange
Old Jan 16, 2010 | 12:22 PM
buzzsaw's Avatar
Car: 89 RS
Tach acting strange
This may be covered somewhere but I couldn't find it. After a couple of months on not driving my 89 RS I cranked up to go for a drive recently and noticed that even though the engine was not over revving my tach was indicating about 3000 rpm and when up to road speed it increased to around 7000. After a short drive and time to warm up when I stopped for a stop sign it came down to a reasonable 900 or thereabouts but went back up to the peg when up to road speed. I am certain based on sound and such that the engine was not turning anywhere near that fast. Trans shift appeared normal etc. The car has a 305 which as far as I know is original. I bought it some years ago with less than 100,000 on the clock but currently have about 247,000 on it. Any ideas what is wrong and how to fix???
Old Jan 16, 2010 | 06:37 PM
chefman45887's Avatar
Car: 89 Camaro RS
Engine: 283 SBC
Re: Tach acting strange
speedometer cable could have went out after all of those miles. I own a 89 Rs too, the speedo was busted took about 1/12 hour to replace.
Old Jan 16, 2010 | 09:06 PM
buzzsaw's Avatar
Car: 89 RS
Thanks for the reply. The speedo seems to be working fine except for the trip odometer which stuck sometime back when I zeroed it. Is it possible that the two are tied to the same cable and one work and the other not?
Old Jan 17, 2010 | 04:14 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Something's screwy between the ignition coil and the tach... Speedo is completely independent of the tach, so even if the cable to the speedo were bad, the tach would do the same. Check the resistance on the white wire at the coil between the coil and the dash pin.
Old Jan 17, 2010 | 10:06 PM
buzzsaw's Avatar
Car: 89 RS
Thanks, appreciate the tip. Since it sat without cranking for a couple of months and I live near the beach corrosion seemed the most likely problem but I didn't know where to start.
Old Jan 18, 2010 | 12:24 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Strange Range
Your problem is in the circuit inside the dash that moves the pointer.
It’s contained on a small plug-in PCB or integrated in the main board.
On the PCB you’ll see a resistor chip.
Desolder pins 4 & 10.
Use a 500K potentiometer.
Solder it across traces 4 & 10.
Move the potentiometer to half way.
Start the engine and compare the tach reading with a test equipment quality tach.
Dial it in, unsolder one side of the potentiometer, measure it and buy the matching resistor.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
ironbmt
Sep 27, 2015 06:00 AM
