Overdrive warning light
Old Jan 16, 2010 | 03:06 PM
TERRY LAPORA's Avatar
I'm not sure if this is the proper section to ask this question, but here it is. When cruising in Drive at hiway speed, I put the automatic trans gear selector into O/D. Within one minute the "check engine" light comes on, but there is no change in vehicle operation and the light remains on until I restart the engine. Is this cause for concern?
Old Jan 16, 2010 | 03:09 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Overdrive warning light
First, you'll need to pull up the trouble code to determine where to start trouble shooting.
Is the CEL off when you shut down and restart?
http://www.troublecodes.net/GM/
Old Jan 16, 2010 | 03:13 PM
The CEL is off when I shut down. Naturally, it comes on when I restart.
Old Jan 16, 2010 | 03:34 PM
Paulo57509,
I was unclear in my reply. CEL goes off when engine is shut down, then comes on momentatily on restart to show bulb is operational, then goes off when engine starts and remains off until O/D is engaged again.
Old Jan 16, 2010 | 07:56 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Best thing to do at this point is pull the trouble code per the link in my previous post. This will give you a place to start your diagnosis.
Old Jan 16, 2010 | 08:03 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
sounds like a code 32 to me.
Old Jan 16, 2010 | 08:59 PM
Kwik89GTA's Avatar
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
Crazy EGR Code 32.......
383cam
Sep 9, 2015 06:01 AM
TBRays98
Sep 6, 2015 05:05 PM
Jetmeck
Sep 4, 2015 12:29 AM
luvofjah
Sep 3, 2015 07:08 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
