i need some help please distributer wires cut
Car: 1991 camaro rs convertable
Engine: 305tbi
i have a 1986 camaro z28 with a 305 tpi the wires that come from the car and clip to the distributer are cut one is pink i dont know where it goes and one is white i dont know where on the distributer they go can i see some pics of your guy ones please i need help
thanks
thanks
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: i need some help please distributer wires cut
They don't go onto the dizzy... Those are supposed to be in the gray connector on the ignition coil for the primary side of the circuit. There are no pink or white wires at the dizzy itself (unless you have an older style HEI dizzy, in which case they would go to the coil in the cap).
Engine: 305tbi
its out side the distributer on the case of it its all stock down to the org tires and head lites
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
I Need To Get A Tan Myself
If you’re confusing TAN with PINK , the TAN wire goes to pin B of the module.
The WHITE one goes to pin D.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime,
and the nitwits that need headlights for a little rain
Happy Racing!
If People Drove Any Slower They’d Be Going BackwardsWhen you see fog lights on in good weather beware. Low performance driver ahead.
Engine: 305tbi
thanks guys i found out yesterday and i got another probilm now guys when i started it there was no oil prussure even when i gave gas and there was a lil smoke caoming from the valve cover too what duzz this mean?
Transmission: 765R4
OIL TOIL
Check your pressure gage to make sure it’s functioning.
If the car hasn’t been run in a long time you might have a clogged line or pump.
Until you get pressure do your testing with the starter motor.
Happy Racing!
Happy Racing!
db057
Aug 11, 2015 10:11 PM
