Which VSS?
Car: 91 Camaro RS
Engine: Freshly rebuilt 350 with goodies.
Transmission: 700R4 w/ 2000 Stall
Which VSS?
The car I'm working with has a bad VSS (no speedo activity and throwing code). It is a 91' RS body and 700r4, but it's mated to an 87' TPI ECU. So which year does it need? Also it seems there are a couple of sizes available from autozone, depending on the year.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Which VSS?
You need a VSS to suit the computer not the car
VSS pulse signal changed in '90 from 2000 to 4000
Car: 91 Camaro RS
Car: 82 Z28
Transmission: T400
Car: 91 Camaro RS
Re: Which VSS?
Old VSS' had a hold down bracket similar to the one on the distributor
Older VSS' reversed the wires. Before you buy a new VSS, switch the wires and see if your speedo works again
Car: 91 Camaro RS
Re: Which VSS?
The VSS went out before the swap, so it's dead. I went ahead and ordered the sensor that is correct for the transmission and a Dakota SGI-5 to correct for the older computer and the 3.73's. Thanks for the wiring info, that may come in handy depending on how it was wired back to the ECU.
Re: Which VSS?
Discontinued from GM (was the B4C VSS)
Look here
http://www.jagsthatrun.com/SpeedSensors_Order.html
Or here
http://www.transmissioncenter.net/sp...n_______va.htm
Look here
Or here
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
