buzzer relay?
Old Jan 19, 2010 | 10:09 AM
campbellerman's Avatar
Car: 1990 Trans Am
Engine: 305 TPI L98 cam
Axle/Gears: 3.42 eaton
buzzer relay?
ok my car is missing a relay under the driver side dash and the place is marked "buzz". does this have anything to do with the buzzer? the buzzer has never worked since i got it and i just noticed this lil empty hole yesterday. i have looked on advance and autozones websites to try and find one but havent had any luck. does anybody know where i can get one of these little relays or switches whatever the hell it is?
Old Jan 19, 2010 | 11:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: buzzer relay?
Originally Posted by campbellerman
ok my car is missing a relay under the driver side dash and the place is marked "buzz". does this have anything to do with the buzzer? the buzzer has never worked since i got it ....does anybody know where i can get one of these little relays or switches whatever the hell it is?
The former owner probably removed it because of the annoyance factor. I'm not sure whether they're still available new or not, but the bone yards should be full of them.
JamesC
Old Jan 19, 2010 | 11:19 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
DELETED BY NINÅ
REDUNDANT POST
Old Jan 19, 2010 | 03:21 PM
Car: 1990 Trans Am
Re: buzzer relay?
what year cars had these relays? my 86 doesnt have one. at least i didn't see it i mean i could be wrong.
Old Jan 19, 2010 | 03:38 PM
JamesC's Avatar
Re: buzzer relay?
The seat belt-ignition key-headlight buzzer is located in the convenience center as you've found. As far as I know, all thirdgens were equipped with them.
The center includes horn relay, the above buzzer, choke relay (vacant w/EFI), hazard flasher and signal flasher.
JamesC
Old Jan 19, 2010 | 03:43 PM
Car: 1990 Trans Am
Re: buzzer relay?
ok i found it thanks for all your help
Old Mar 22, 2010 | 12:14 PM
Iroc-Dennis's Avatar
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
Re: buzzer relay?
will it give any problems if you let it out??
it is a crazy sound , i dont like it!!!
Old Mar 22, 2010 | 04:00 PM
Car: 1990 Trans Am
Re: buzzer relay?
no it wont cause any problems just the fasten seatbelts light will not illuminate
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
