Washer not working, Pump is OK
Old Jan 19, 2010 | 01:01 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
The washer in my car is not working. I have tried a couple different pumps, so I can rule out a bad pump. Can somebody help me to get it working?
Old Jan 19, 2010 | 01:25 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
You Can Always Pay Someone To Sit On Your Roof With A Rag.
Grab your voltmeter.
Are you getting voltage to the pump when you hit the button?
Old Jan 19, 2010 | 01:32 PM
osso12's Avatar
Car: 85 Z28 Vert
Engine: LG4 ENGINE 5.0 4BBL
Transmission: 700R 4SPD
Axle/Gears: 3:08
Re: Washer not working, Pump is OK
Ditto what he said. If your getting voltage, I had the same problem.
read this thread and get back with us of all else fails.
https://www.thirdgen.org/forums/tech...sher-dont.html
Old Jan 19, 2010 | 03:10 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Ok well maybe the pump could possibly be bad. I hooked it up to a ground and a 12v source, and it just sparked. Does this mean the pump is bad?
Old Jan 19, 2010 | 03:15 PM
osso12's Avatar
Car: 85 Z28 Vert
Axle/Gears: 3:08
Thats what mine did. It arc pretty well and did nothing.
Replace your pump. I think you can one at O'reillys if you have one in your area
for $13.00
thats what a paid. Auto zone, ect. Whatever store you have in your area should stock it.
BTW, you dont have to remove the whole assembly like I did, it just makes it easier to get to. Just unplug your two hoses and it should just pull straight down to the bottm.
Old Jan 19, 2010 | 03:16 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Ok, ill try that and see how it works out. Thanks for the help.
Old Jan 24, 2010 | 02:23 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I just put a brand new pump in and it still isn't working. Exactly what wires do I need to test for power?
Old Jan 24, 2010 | 02:31 PM
osso12's Avatar
Car: 85 Z28 Vert
Axle/Gears: 3:08
Are your wipers working? Do you hear the pump do anything at all?
Double check all your fuses then let us know what it is doing.
#16 shown shows to be the wiper motor fuse in this diagram:
https://www.thirdgen.org/forums/elec...-breakers.html
Old Jan 24, 2010 | 02:48 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Wipers work, but you cant hear the pump run.
Old Jan 24, 2010 | 02:54 PM
osso12's Avatar
Car: 85 Z28 Vert
Axle/Gears: 3:08
Just a thought... Remove your new pump again, hook 12 volts and a negative to it and make sure it runs. If it runs, we will know we got a short somewhere.
Old Jan 24, 2010 | 05:35 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I pulled the new pump out of the car and hooked 12v to it and it ran. What should I look for now
Old Jan 24, 2010 | 06:09 PM
osso12's Avatar
Car: 85 Z28 Vert
Axle/Gears: 3:08
Did you check the fuse?
Old Jan 24, 2010 | 06:47 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
If the fuse is good, try using a light on the connector to see if there's any juice going to the pump. Your connector could be corroded and just needs to be cleaned.
Old Jan 24, 2010 | 07:09 PM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Check your pigtail connector coming off the harness. I had the same problem and that was the culprit.
Old Jan 24, 2010 | 08:03 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
The fuse is good. Which terminal in what connector should I check for power at? Im not sure where the pigtail connector is that your talking about. Is it the one that goes right to the wiper motor cover?
Old Jan 24, 2010 | 08:27 PM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
the one that you plug into the pump
Old Jan 24, 2010 | 09:35 PM
Car: 87 T-Top GTA
Once the pigtail/connector is cleaned, plug it back on and try it. If it still doesn't work, I would do a continuity test on the 2 wires for the wash pump motor, to find where and which wire is broken. If Both wires test good, then your problem lays within the lever/wiper switch.
http://cgi.ebay.ca/PONTIAC-FIREBIRD-...item20af0c1572
Old Jan 25, 2010 | 12:01 AM
osso12's Avatar
Car: 85 Z28 Vert
Axle/Gears: 3:08
The problem is that the pump if it is like mine will plug internally into the wiper motor. I do not know how he can check a internal connection like that.
Old Jan 25, 2010 | 08:32 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
My pump plugs into the wiper motor itself, not the bottle like osso12 said. The only thing that goes to my pump is two rubber hoses. So does anyone else know which wire I have to check to see if their is power going to my pump?
Old Jan 25, 2010 | 12:17 PM
NINÅ's Avatar
Transmission: 765R4
From post 2, we are now here.
You will now probe pin B going to the wiper motor plug.
Have a friend press the washer switch.
If you get 12 volts at pin B proceed to pins D&E which is the connection for the washer pump.
Put your meter or test light across those pins (one test lead on pin D, and the other test lead on pin E) to see if you’re getting 12 volts there when the washer switch is pressed.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
Old Jan 27, 2010 | 11:28 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Well the washers are now working, but I have a new problem. That blue plastic cam/rotor? that goes to the wiper motor cover is broken off. Can I just get a new cover from a 2 speed wiper car?
92camaroJoe
Jul 29, 2023 07:57 PM
mustangman65_79
Apr 14, 2017 05:37 PM
backtothe80s
Sep 5, 2015 12:39 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
