Turn signal help
Old Jan 23, 2010 | 02:09 AM
marekdennhardt's Avatar
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Turn signal help
When I turn use my turning signal switch nothing happens. It clicks into place but nothing happens.
Any help would be appreciated.
Old Jan 23, 2010 | 03:07 AM
thecraze's Avatar
Re: Turn signal help
If the light comes on, but just sits with the turn light on, it's just the flasher.
Old Jan 23, 2010 | 11:14 AM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
I wish that was the case. But nothing happens. No lights at all.
Old Jan 23, 2010 | 01:36 PM
Wolfskin's Avatar
Car: 87 Z28 and 90 Grand Prix STE
Engine: Z28-project 454, STE-turbo 3.1L
Transmission: Z28-4l80e, STE-4T65
Axle/Gears: Z28-truck 12 bolt posi 3.73
have you checked your bulbs? probably not the problem if none of them work, but start with the cheap and easy. then there is the fuse box. after that it's time to start chasing wires. good luck.
Old Jan 25, 2010 | 11:49 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Simply Drive Straight Till You Fix The Problem
If the TURN-B/U FUSE is good put the key in the RUN position.
See if you’re getting voltage at the
PURPLE wire exiting the turn flasher.
Report findings as necessary.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
Old Jan 25, 2010 | 04:25 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
See if you’re getting voltage at the PURPLE wire exiting the turn flasher.
Alright. What is a b/u fuse and where is it located. Also where is the purple wire (where is the turn flasher?)
thanks
Old Jan 26, 2010 | 01:06 PM
NINÅ's Avatar
Transmission: 765R4
The TURN-B/U FUSE passes power to the turn signals, backup lamps, plus another circuit.
The turn signal flasher is located inside the “Convenience Center”. To gain access to the turn signal flasher, it might be necessary to remove the knee bolster. The convenience center, located to the left of the steering column, should swing down.
Happy Racing!
Old Jan 26, 2010 | 07:47 PM
thecraze's Avatar
Re: Simply Drive Straight Till You Fix The Problem
In my Camaro, the turn signal flasher is NEAR the convenience center. There is a space, next to the hazard flashers, with no connectors. It drove me crazy. I eventually reached up the the convenience center, and found the turn signal flasher mounted by a simple clip.
Old Jan 28, 2010 | 01:57 AM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
hmm.. What does it look like?
Old Jan 28, 2010 | 09:05 AM
NINÅ's Avatar
Transmission: 765R4
The turn signal flasher is a can about 1” by 1”.
It can be any color, metal or plastic, when you unplug it you will see the 2 blade terminals.
Happy Racing!
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
