Car does not turn-off
Old Jan 21, 2010 | 02:01 PM
cam.crazy's Avatar
I have a Camaro 91 RS 305 (TBI). It has a strange problem. Recently I discovered that the fuel pump's fuse that is located next to the battery is burned although the car is running ok. so I replaced it with the same AMP fuse. After that the car does not turn-off even with the ignition key in off position. So I took out again the repaced fuse to turn-off my car. did anyone faced such a problem like this...please help....
Old Jan 21, 2010 | 03:43 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Car does not turn-off
Sounds like a possible short somewhere. For an EFI car to keep running at key off, there must be 12V getting into places where it does not belong, at least into the ignition leads to make the ECM think the key is still in the run position. I dont recall exactly whats on that circuit, but I do know that the ECM and fuel pump share power from that. That would go a long way to explaining why it keeps on truckin even when you turn it off.
Old Jan 22, 2010 | 11:13 AM
cam.crazy's Avatar
Thanks, I think the most difficult thing is to trace a short circuit in the car. what is the best way to do this?
Old Jan 22, 2010 | 11:51 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Car Wants To Go Go Go !, But I Want To Stay Home
The PO probably jerry rigged the fuel pump wiring when the fuse burnt.
Look along those lines for some sloppy wiring.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
