Gauges
Old Jan 21, 2010 | 05:12 PM
82_Z28_Camaro's Avatar
Car: 1982 Z28 Camaro
Engine: 5.7L 350
Transmission: TH350
Gauges
Whats the easiest way to replace the speedo cable? and also my gas gauge just stands straight up when i know there's only a fourth of a tank left.
Old Jan 22, 2010 | 11:41 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
We Don’t Get Fueled Again !
Here’s how to test the fuel gage.
Remove the sender wire going to the gage.
Use a potentiometer with a value of 90Ω or the closest you can find.
Connect one end the potentiometer to the gage from the location you removed the sender.
Connect the wiper of the potentiometer to ground.
Turn the key to RUN.
Slowly adjust the potentiometer from 0Ω to 90Ω.
If the gage is bad it will exhibit the problem you have.
If the gage is good it will display a smooth transition from end of it‘s range to the other.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
