Fuzzy Speakers
Old Jan 21, 2010 | 07:14 PM
POPODYNAMO's Avatar
Car: 84 Camaro Z28
Engine: 305 HO
Transmission: 700-R4
Fuzzy Speakers
I have an 87 camaro stereo in my 84. But the previous owner had cut the wires for an aftermarket. So i had to do my own wiring and everything works except that when i turn the volume over 22 it starts to get real staticy. Idk if its just bad wiring or what?? But if u know how to fix it please tell.....
Old Jan 21, 2010 | 07:24 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Re: Fuzzy Speakers
Could be a bad ground my car did the same thing I'd crank up the volume and when it would draw more power it would start popping. To fix it I took some wire and wired it from the headunit to the seat rail bolt and problem solved. I also wired the ground from the battery to the body being it was hooked up to the engine and I did notice better sound quality but not a huge difference.
Old Jan 22, 2010 | 06:25 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Fuzzy Speakers
It's possible that what you're hearing is distortion from a head unit which has insufficient power to rock hard and clearly. If so, be careful not to blow your speakers. For a more specific answer, you might try the Car Audio forum.
JamesC
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
wanext
Oct 6, 2015 12:18 AM
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
codeysabatini
Sep 20, 2015 11:36 AM
