please help! high beam problem
Old Jan 22, 2010 | 08:01 PM
DPALz28's Avatar
Car: 1982 CAMARO
Transmission: 3 SPD AUTO
my low beams work fine but when i pull the lever back to turn on the high beams, they cut my low beams off... do you think the switch is bad or the wiring?? please help.
Old Jan 24, 2010 | 07:35 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Re: please help! high beam problem
Your low beams should be 2 filament bulbs. (3pin plug on headlights) your high beams are high only one filament (2 pin plug). Provided you have the proper lights the high beam filament is probably burned out on both your low beam bulbs.....good luck.
Old Jan 25, 2010 | 02:56 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Bright Idea
If you mean the highs don’t come on the high beam switch might need adjusting.
You can gain access to it at the bottom of the steering column.
When you pull the lever you'll see the moving rod and the switch.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
GTAman
Mar 15, 2019 11:40 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
