A huge drain
Old Jan 23, 2010 | 02:37 PM
Wolfskin's Avatar
Car: 87 Z28 and 90 Grand Prix STE
Engine: Z28-project 454, STE-turbo 3.1L
Transmission: Z28-4l80e, STE-4T65
Axle/Gears: Z28-truck 12 bolt posi 3.73
A huge drain
Ok, so i just bought this 85 t/a and it has a huge drain that can kill a new battery in about 15 minutes. It seems fine untill I turn the headlights on. I drove around all day yesterday with the radio on, and wipers going, and everything was cool. Then I turned on the headlights, and it was done. I haven't gotten a good look at whats going on with all of it yet, but my headlights are locked in the up position, guess one of the motors died. I pulled the alt and had it tested, and it's good, but somehow this thing is just killing the battery, even while driving at 60mph. Any idea before I go and start taking things apart? oh, I don't think it's important, but the left fog light doesn't come on, and the right turnsignal doesn't flash. Hope the's a lot of us on here right now. Thanks.
Old Jan 25, 2010 | 03:02 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Huge Drain, No Water, Who Needs It ?
Sometimes the under-hood light does not go out so check that easy one first.
Then connect an ammeter in series with the battery.
With everything turned off and doors closed observe the current flow.
Pull the fuses one at a time till you see the current drop.
That’s the circuit with the problem.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
Old Feb 27, 2010 | 05:20 PM
grandpa roxy's Avatar
Re: Huge Drain, No Water, Who Needs It ?
[quote=NINÅ;4412818]
Happy Racing!
[/quote There should be relays for headlight motors and they are powered off fusiblle link could be headlight motor stuck drawing power
Old Mar 1, 2010 | 05:25 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: A huge drain
I would check out the wiring on the charging system. I mean a stock alternator should be able to out out at least 50-60 amps thats pretty huge. To kill a car thats running its got to draw over that amount plus drain the battery which also has a huge charge on it. If you had a current draw that was that big ide guess it would blow fuses or melt wires first. Im guessing your alternator although good maybe but the wiring is bad not allowing it to charge eventually killing the battery.
SRKLEGIN
Oct 29, 2015 06:38 PM
85cmroz28
Oct 4, 2015 09:44 PM
raymondandretti
Sep 27, 2015 06:43 PM
ericjon262
Sep 11, 2015 06:07 PM
89 formula TPI
Sep 7, 2015 11:06 AM
