Shifter Wiring
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Shifter Wiring
Was there a difference in wiring from my 89 camaro automatic shifter to a 70-72 camaro automatic shifter? Or could I just plug n go.
Re: Shifter Wiring
Alot Im guessing
3rd gen has two wires for the starter safety switch
Two wires for the back lights
Two wires for the P/Neutral switch to the ECM
No idea on the 2nd gen shifter
Why are you using it?
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Shifter Wiring
A 2nd Gen shifter would need another detent too.
He probably wants a shifter that works kind of like 1/2 of a Hurst Dual Gate; some 2nd Gen shifters had this feature. They won't skip ranges on the upshifts.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Shifter Wiring
Its a project, I'm going to be installing a 70-72 camaro horseshoe shifter. And I noticed the wires and wanted to make sure they will plug right in. Also i'm going to make my own shift console plate.
Car: '87 IROC
Engine: LB9
Re: Shifter Wiring
If you're still looking for a stirrup shifter, you don't have to find a 70-72 Camaro shifter. GM started using them in 1968. I've also seen them in Buick Skylarks.
My friend has one in his '68 El Camino. It's hooked up to a 700R4. I can't recall if he mod'ed it to get the extra detent or if he just uses it without first gear.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Shifter Wiring
I wanted the 70-72 because of the long base plate it has so i can bolt it to the body. the 68-69 had a small one. I found the adapters & cable for it to use everything.
1992 Trans Am
May 10, 2023 07:19 PM
NBrehm
Aug 25, 2015 11:49 PM
Dialed_In
Aug 20, 2015 01:45 PM
