Tachometer problem
Old Feb 4, 2010 | 08:08 PM
osso12's Avatar
Car: 85 Z28 Vert
Engine: LG4 ENGINE 5.0 4BBL
Transmission: 700R 4SPD
Axle/Gears: 3:08
Tachometer problem
Stock tach on the 85z.... Got another tach from a member on here. Tach is not the issue as it is doing the same thing the original tach to the car is doing.
Heres what happens. When you turn the ignition to "on" without starting the car
the tach slowly climbs to pegline 7 grand....
Turn the ignition switch off, tach remains at 7 grand.
The oil pressure guage that is w/ the tach is fine.
When you start the car, The tach automatically jumps to 7 grand or peg redline.
Sounds like an electrical short. I realize that I only have to have hot and an ignition to run the tach. My question is, how can I test the factory connection wires at the distributor? There are two wires that go to the distributor, both are marked on the cap. This is the same exact problem I had with the old tachometer.. Its like it has a short in the wire some where I suppose. What can I do? I would really like to get all the factory guages working but its getting less likely each day.
Old Feb 5, 2010 | 09:49 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Tach Yack
The problem is in the circuit inside the dash that moves the pointer.
It’s contained on a small plug-in PCB or integrated in the main board.
On the PCB you’ll see a resistor chip.
Desolder pins 4 & 10.
Use a 500K potentiometer.
Solder it across traces 4 & 10.
Move the potentiometer to half way.
Start the engine and compare the tach reading with a test equipment quality tach.
Dial it in, unsolder one side of the potentiometer, measure it and install a matching resistor.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
Old Feb 8, 2010 | 12:04 AM
osso12's Avatar
Car: 85 Z28 Vert
Axle/Gears: 3:08
Re: Tach Yack
thanks!
Old Feb 9, 2010 | 10:25 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Tachometer problem
It'sd possibly a bad Printed Circuit on the back of the speedo cluster. Over the past few years I've noticed more and more bad printed circuits,.... MANY are beginning to "seperate" after 20 + years of service.
Old Feb 10, 2010 | 03:33 AM
osso12's Avatar
Car: 85 Z28 Vert
Axle/Gears: 3:08
Thanks....out of the 6 guages... I can only get three to work correct..
The speedo, the oil pressure, and the gas guage......
I think I am going to replace the whole cluster if I can find one cheap enough.
It would be the easiest way for me to do the repair.
Age can be a bugger. I am surprised more have not chimed in with the same or similiar issues.
Old Feb 11, 2010 | 01:37 PM
John in RI's Avatar
No Problem !
Keep in mind; if you get a replacement cluster than be sure it's not an 82-84 version,...... You will need an 85-89 style or there will be a compatability problem with the 85's dash harness causing a conflict with the E-Brake warning Light and the backlighting.
Old Feb 11, 2010 | 07:11 PM
osso12's Avatar
Car: 85 Z28 Vert
Axle/Gears: 3:08
yes, Ill be sure its 85 up..
Thanks!
Old Feb 21, 2010 | 11:13 AM
f-bodymikey's Avatar
Car: 84 Z-28
Engine: 355 4 bolt main
Transmission: 700 R4
Axle/Gears: Posi 3.73
Will there be an issue swapping an 85-89 gauge cluster into an 84 model. None of my idiot lights work anyway. Cause the computer isn't hooked up anymore. Thanks
Old Feb 21, 2010 | 11:27 AM
John in RI's Avatar
The 85-89 cluster is not directly compatible with the 82-84 dash wiring. The BRAKE warning light was placed in a different location on the cluster and the printed circuit on the back of the cluster was re-engineered as a result. One of the cluster "backlight" bulbs is also effected by this difference.
Mikey; You could probably re-pin the dash connectors, but the easiest way to go is to use a 82-84 gauge cluster if your looking for "plug-&-play" installation.
P.S. The "idiot" lights are not controlled in any way by the ECM. The engine sensors feed the gauges directly to the cluster.
Old Feb 21, 2010 | 11:35 AM
Car: 84 Z-28
Well I didn't know that I thought the idiot lights were controlled by the computer. Sometimes the brake light does light up when I first turn on the key but none of the others come on. Is that a problem with the cluster it's self?
Old Feb 21, 2010 | 07:52 PM
88iroctpi305's Avatar
Car: 1988 Camaro IROC-Z and 91 Z28
Engine: 305 TPI and 350 TPI
Axle/Gears: unsure of ratio but POSI (:
my gauges are messed up as well. when i turn on the dash lights my rpm's just peek out. and my gas gauges is on full when i know its not "full" and my temp gauge doesnt work? im thinking its a ground? can anyone help please.
Old Feb 21, 2010 | 11:02 PM
John in RI's Avatar
The Tach and lighting systems should not be related or dependant on each other in any way. I'd suspect a bad printed circuit in your cluster too.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
