Tail Light/Brake Light Socket Replacement - 90 RS
Old Feb 6, 2010 | 09:26 AM
90RSDriver's Avatar
I think my old tail light/brake light socket has a short in it somewhere (caused by me using a sharp tool and WD-40 to remove the old bulb casing) and I'd like to replace it. However, all of the new sockets that I can find have three wires, whereas my original socket has four wires. Can I make the three wire sockets work? If not, where can I find a new four wire socket?
Old Feb 8, 2010 | 12:38 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Socket 2 Me
The three wire socket will work.
The fourth wire on your socket is connected to the third wire so it can be directed to the next socket in the car.
When you hookup the new socket connect the double wire to the one wire on the new socket.
Hopefully the new socket’s wires are color coded the same as the original socket.
Otherwise an ohmmeter will solve the problem.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
Old Feb 14, 2010 | 08:06 PM
90RSDriver's Avatar
Re: Socket 2 Me
Great, thanks for the help. I have two blue wires on the old one so I'll just connect those to the white wire on the new socket and I should be good to go.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
