Need starter help
Old Feb 6, 2010 | 10:15 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Need starter help
I have a 91 3.1 Camaro. Ever since I've had the car, it acts like the starter solenoid is bad. You turn the key, sometimes it just clicks then finally it'll engage the starter. I've replaced the solenoid and the starter and still have the problem.
Recently, I had the engine out of the car so I did some testing on the starter with it in the car. Every single time you hit the key, the starter worked. Once I put the engine back in, I was having problems again.
Here's my thoughts... possibly still a solenoid or starter problem but not likely. Possibly a bad wire somewhere that was either making better contact the way the starter was position without the engine in OR just a bad wire the once it has the load of trying to turn the engine over, won't carry the amperage. Any thoughts or experiences? I'm getting really tired of this problem! Thanks!
Old Feb 6, 2010 | 10:54 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Need starter help
I'm currently having the same problem. Mine will only do it sometimes, maybe 1 out of 10 starts. I can't get it to do it on command, so it's a pain to try and troubleshoot. I'm thinking it might be the VATS starter enable relay, I'm going to try replacing that.
Old Feb 6, 2010 | 06:37 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by AM91Camaro_RS
sometimes it just clicks then finally it'll engage the starter. Possibly a bad wire somewhere that was either making better contact the way the starter was position without the engine in OR just a bad wire the once it has the load of trying to turn the engine over, won't carry the amperage.
Clicking shows the solenoid is working but not turning over means the starter is not getting enough power.
Check batt connections and the main ground wire from batt to engine for loose / bad connections ( assuming your batt is good)
Old Feb 6, 2010 | 06:40 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by Ward
I'm currently having the same problem. I'm thinking it might be the VATS starter enable relay,
If you get any activity ( clicking ) from the starter is not VATS related because the start enable relay has to be working for the power to get to the solenoid.
If VATS related , turning the key to start gets you
Old Feb 6, 2010 | 06:56 PM
Car: 91 Camaro
Yeah, I had wondered about VATS but had ruled it out do to what vetteoz said.
As far as the battery and possibility of loose connections...I've had atleast 2 batts in it and have had all of the connections off and back on a few times.
I appreciate the ideas, though! Keep them coming, please!
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
