alternator what amp?
Old Feb 14, 2010 | 07:29 PM
techno_1961's Avatar
so theres a few different amp alternators out there i have a 86 iroc 305 tune port injection with a/c what amp alternator does my car call for?
Old Feb 15, 2010 | 02:25 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: alternator what amp?
Hello techno_1961!!
My 1987 Iroc 305 TPI without A/C has the 105 amp alt, yours I believe is 78 amps. You can check that out by looking at the alt case, the info is stamped into it.
Old Feb 15, 2010 | 12:43 PM
weaz4200's Avatar
Car: have a 92 camaro rs...in pieces
Engine: none now...probably 383 stroker
Transmission: none yet
Axle/Gears: none
Could be any one of these....
42 Amp 1979865
78 Amp 10463058
94 Amp 10463397
100 Amp 10463014
105 Amp 10463104
108 Amp 10464391
120 Amp 10464392
Old Feb 15, 2010 | 10:21 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
probably will be a 97 or 108 a 17si type,those were used
on '85 and'86 tpi models. Could also be 120a,depending
on options.Late production '86 could have cs144 type.
Old Feb 17, 2010 | 11:23 PM
Hello again techno_1961!!
Check your RPO codes if you got them, a K68 will be for the 105 amp alt!!
If you have a different RPO than K68, run all your "K" series RPO's in the RPO decoder, you should be able to find it out from them!!
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
