Jumped a relay now fuel pumps dead
Old Feb 14, 2010 | 10:25 PM
Despiser87's Avatar
Car: 88 Camaro
Engine: 5.0L v8 TBI
My radiator fan was not coming on at all. I just replaced the motor so I know it works. So while the camaro was running I tryed jumping the radiator fan relay by touching the red and tan/white wire to see if the fan would come on. I held it the jumper wire there for maybe 3 seconds and the engine died. The fuel pump will not turn on now. I think I fried something or possibly blew a fuse somewhere. I checked all the fuses under the dash (I should have checked them to begin with) and found the fuse to the fan was blown. All the other fuses down there look good.
What fuses are in the engine compartment that I should check and where are they? Also I tried jumping the fuel pump relay and nothing happened. Did I fry my fuel pump?
88 camaro 305 TBI
Old Feb 15, 2010 | 03:00 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Jumped a relay now fuel pumps dead
There's an inline fuse near the battery which powers the ECM and fuel pump, I would check that.
Old Feb 16, 2010 | 07:40 AM
Despiser87's Avatar
Car: 88 Camaro
Engine: 5.0L v8 TBI
I checked that inline fuse near the battery it looks good. Still cant figure out what the problem is.
Old Feb 16, 2010 | 10:59 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Waitress, I’ll Have Fried Pump To Start, Followed By Sparkplugs Jubilee
Probably not.
Use a test light to see if you have power on pin A of the pump relay (
ORANGE WIRE).
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
Old Feb 16, 2010 | 11:04 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
There is also a fusible link near the battery. Check and see if it looks burned or melted at all. Mine was half-melted, causing the fuel pump not to run - I cut it out and replaced it with an inline fuse holder and 30A fuse.
Old Feb 20, 2010 | 01:52 AM
Despiser87's Avatar
Car: 88 Camaro
Engine: 5.0L v8 TBI
Re: Waitress, I’ll Have Fried Pump To Start, Followed By Sparkplugs Jubilee
I used the test light on the pump relay on the orange, red, and the tan/white wire none of them worked. I tryed the test light also on the fan relay and from there the tan/white showed power. I also tryed the test light on the wires at the fusible link near the battery no power there either.
Old Feb 20, 2010 | 01:54 AM
Despiser87's Avatar
Car: 88 Camaro
Engine: 5.0L v8 TBI
I checked the fuse near the battery also and it was good.
Old Feb 22, 2010 | 09:16 AM
NINÅ's Avatar
Transmission: 765R4
If you’re getting power out of the fusible link, but it’s not making it to the pump relay, you have a bad connection from the link to the socket.
Probe the run till you find drop off.
Happy Racing!
Old Feb 27, 2010 | 08:00 AM
Despiser87's Avatar
Car: 88 Camaro
Engine: 5.0L v8 TBI
I have no power at that fusible link either.
Old Mar 1, 2010 | 09:17 AM
NINÅ's Avatar
Transmission: 765R4
Trace the link back to the battery to find the break.
Happy Racing!
When you see fog or “running” lights on in good weather beware. WLow performance driver ahead.
Old Mar 8, 2010 | 01:54 PM
Despiser87's Avatar
Car: 88 Camaro
Engine: 5.0L v8 TBI
This fusible link near the battery is an orange and red wire. Are these the wires connected to the ecm that give power to the fuel pump relay? If so Is it possible I fried my ecm when attempting to jump the fan relay?
Old Mar 8, 2010 | 02:59 PM
NINÅ's Avatar
Transmission: 765R4
Fried ECM To Go And A Large Coke
It is probable you damaged the ECM if you let power touch pin F.
Happy Racing!
Old Mar 10, 2010 | 03:27 PM
Despiser87's Avatar
Car: 88 Camaro
Engine: 5.0L v8 TBI
Is there a way I can test to see if its the ecm causing the problem? If it is the ecm not telling the fuel pump to turn on could I just wire a switch so that I can send power directly to my fuel pump so that theres no need to replace the ecm?
Wheres the inline fuse for the alternator located I around it but did not see one. I read another thread where a guys fuel pump wasnt priming until he changed his alternator inline fuse apparently.
Old Mar 10, 2010 | 03:58 PM
NINÅ's Avatar
Transmission: 765R4
It’s Useable, If It’s Fusible
Yes you can however, so you don’t forget to turn the pump off before getting out of the car, you should wire it to the RUN/START part of the key.
If it is the ecm not telling the fuel pump………..
If only the driver transistor which is in the ECM was blown, the rest of the ECM will work.
The closest fusible link associated with the alt is near the starter solenoid.
Happy Racing!
Old Mar 12, 2010 | 06:21 PM
johnnymotz27's Avatar
Car: '89 L98 G92 Iroc /'11 GS Vett
Engine: L98/LS3
Transmission: 700R4/M6
Axle/Gears: 3.27 B.W./3.42
Re: It’s Useable, If It’s Fusible
Hey there having a similar problem with my fuel pump......Could this be why there is a wire run from my coil to the orange wire in the fuel pump relay?
Old Mar 15, 2010 | 08:12 AM
NINÅ's Avatar
Transmission: 765R4
Yes, most likely the PO blew the fusible link on your car.
Happy Racing!
Round Out Your Life, Drive Oval Tracks
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
