electric fan in a '83 TA?
Old Feb 22, 2010 | 10:50 AM
mjk1210's Avatar
Car: '83 TA
Engine: GM Performance 350
Axle/Gears: the slowest off the line
I was thinking of installing an electric fan in my 83 TA and disconnecting the pulley fan. What are your tips for doing the switch over and recommendations on a fan (or dual fans.) And is it worth the hassle/expense for fuel or engine power.
Old Feb 22, 2010 | 04:38 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: electric fan in a '83 TA?
I swapped to a single electric fan and serpentine setup in my old 83, and it made a noticeable difference. The engine would rev a little faster, and was much smoother. However, I'm not sure how much of it was from the fan, and how much was from the serpentine belt.
Old Feb 22, 2010 | 05:16 PM
mjk1210's Avatar
Car: '83 TA
Where did you get your fan and how well does it work? I like the serpentine belt idea. Is that a difficult mod, where will I find instructions on that?
Anyone put in an electric fan? What kind? work well? Easy to do?
Old Feb 22, 2010 | 05:33 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
There are dozens of generic electric fan kits on the market and they come with instructions and are fairly easy to do. Keep your existing fan shroud and just take your blade off and find an electric one the right size. A junk yard car with a serpentine set up can be looted for conversion parts.
Old Feb 22, 2010 | 05:35 PM
mjk1210's Avatar
Car: '83 TA
great. Thanks.
Old Feb 22, 2010 | 05:43 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
I got everything I needed from a junkyard donor car, and 89ish RS. Everything was a bolt-in install. The serpentine swap was also straightforward. I did have to get a different alternator, since the serpentine setup uses a different one. Also, I got the A/C lines from the donor car, since the alternator and A/C compressor swap sides. I had to lengthen the wires a little for the A/C compressor, and lengthen the alternator wiring, as well as solder on the correct pigtail for the new alternator. I think I also had to run a rubber fuel line from the pump to the carb too, I can't remember if it had a hard metal line to start with.
Old Feb 22, 2010 | 06:02 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No.
The following link may be helpful:
https://www.thirdgen.org/forums/afte...rsion-kit.html
JamesC
Old Feb 22, 2010 | 06:05 PM
mjk1210's Avatar
Car: '83 TA
Thank you very much. That looks useful.
Old Feb 22, 2010 | 06:15 PM
mjk1210's Avatar
Car: '83 TA
ok. I just did some quick research into the fans and there's quite a bit of info. I have a 305 v8 and may be putting in a 350 crate engine soon. What is the fan cfm rating I should be looking for to be sure I don't overheat? Should it be a dual fan? What about amp draw? What's a good number? Or how about a part number that you know will work from Jegs or some other co.?
Old Feb 22, 2010 | 06:34 PM
JamesC's Avatar
Here's what I did, and I've experienced to difficulties with my 350/330 swap. As a matter of fact, the car runs cooler now than it did with the old 305.
https://www.thirdgen.org/forums/cool...electrics.html
JamesC
sheachopper
Jul 31, 2019 11:27 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
