Gauges not working
Old Feb 23, 2010 | 08:59 PM
sparkplug619's Avatar
Car: 1990 RS Camaro
Engine: 305 TBI
Transmission: T-5 stick
Gauges not working
The first gauge not working is the temp gauge, there is a mechanical gauge wired in its place so not really worried about that but is this where the sensor goes? Because there is a sensor connector here and a hole where a sensor would fit.
With this type of plug
the second gauge is my fuel gauge. The previous owner changed the fuel pump so i guess he messed something up while doing that. The needle just sits all the way at the top of the gauge point STRAIGHT up, it doesnt move at all.
To top it all off the gauges dont even light up. I replaced all my fuses, the check engine, brake light etc. all work but the gauges do light up.
Any help is appreciated.
Old Feb 23, 2010 | 09:09 PM
Car: 1990 RS Camaro
Engine: 305 TBI
Re: Gauges not working
found out it IS a temp sensor, but from what I read it not for the gauge, its for the ecu.
I also found another overheating problem, if I have no sensor there, pressure and coolant are escaping out. Wow
EDIT: could be wrong, the temp sensor I was looking at is in front of the thermostat, the one I found is behind on the intake manifold
Old Feb 24, 2010 | 04:24 AM
Car: 1990 RS Camaro
Engine: 305 TBI
Is the sensor a throttle position sensor? I found a picture off google that showed the positions of a few sensors
Old Feb 24, 2010 | 04:57 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
If you have an ECM, you will have a sensor to give it engine temp data... there is also a sender that controls your temp gauge.
A throttle position sensor is going to be on the throttle body. It measures movement of the throttle plate. That is NOT a TPS. Since it has two wires, I make it out to be the ECM temp sensor.
Old Feb 24, 2010 | 08:45 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Send The Solution
Re► Fuel gage. ▬ It sounds like the sender, however to verify, disconnect the sender wire to the gage.
If the gage continues towards FULL the sender is the problem.
Re► No gage lights. ▬ If they failed simultaneously and the other cockpit illumination works, radio illumination, HVAC illumination, etcetera, the problem most likely is a cracked trace (difficult to see) inside the dash.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
Old Mar 3, 2010 | 11:09 PM
Car: 1990 RS Camaro
Engine: 305 TBI
wow i should've known that one. I still havent found out what that lug is for, Been busy trying to bypass the vats.
Old Mar 5, 2010 | 12:52 AM
Car: 1990 RS Camaro
Engine: 305 TBI
crazy, i was going through my wiring and noticed the inst lps wire was clipped and twisted back together. I took a hotwire and touched it to that one to see if that could be the culprit. The gauge lights cut on when I did this.
I was so excited i called my girl out to look while I touched the wire to the inst lps wire. I had her move the dimmer switch but for some reason it would dim the outside lights and not the gauge lights.
I took the wire off and pulled the dimmer switch to turn on my headlights and bam, everything, including my gauge lights popped on. The dimmer works and everything. i guess jumping the wire with a hotwire for a few seconds got it juiced up and working again
Old Mar 5, 2010 | 04:56 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
That's got me scratching my head... I suspect that the spot where it was twisted back together was probably a poor connection. I'd secure that connection and either solder it or wire-nut it to avoid future problems.
Old Mar 5, 2010 | 12:36 PM
Car: 1990 RS Camaro
Engine: 305 TBI
Ya im going to pop a connector over it today
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
Reddeath210
Oct 6, 2015 08:20 AM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
