fusible link location
Old Feb 25, 2010 | 03:34 PM
Kodfish's Avatar
Car: 1990 IROC
Engine: 5.7 TPI
I would like to know where the fusible link ground terminals are suppose to connect to? I have a 90 IROC and the PO had four terminals NOT including the battery wire hooked up to the starter. I know this is not correct and I would like to know where I'm suppose to hook up the terminals to? I've looked at multiple schematics and it doesn't really give the location of the connection.
I got one juction coming right off the pos. side of the batt. that the alt. cable runs too but where should the other four be? I've heard of the location beside the radiator but wouldn't that be grounding the pos. side of the batt. to the chassis? Thanks
Old Feb 25, 2010 | 06:54 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: fusible link location
There are no " ground links"
If wired the same as the '90 Vettes ,then there is a insulated terminal block that all the 12V feed wires inc Alt ( w/ fusible links ) run from.
From the battery pos terminal ,there is one wire to that terminal block and the heavy one to starter
gta892000
Aug 11, 2019 11:16 AM
64goatman
Sep 9, 2015 01:09 PM
383cam
Sep 9, 2015 06:01 AM
tonys91rs
Sep 2, 2015 07:07 PM
