i need help with the tbi vss
Car: 1991 Bird
Engine: Goodwrench 4bolt 357 bore vortec
Axle/Gears: 10 bolt posi disc w/3.23
swaped the tbi for a carb. bye bye ecm.
now i need to get the vss figured out so i maintain its function. and will i have any problems with the VATS system letting me start the car? thanks for your help. i really need it. AUTO FAIR is just around the corner.
now i need to get the vss figured out so i maintain its function. and will i have any problems with the VATS system letting me start the car? thanks for your help. i really need it. AUTO FAIR is just around the corner. Supreme Member
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Speed Reading
You don’t need an ECM but you do need a buffer to convert the VSS sine wave AC to square wave DC.
If you have cruise control add a 4013 chip to divide by 2 to enable that function.
Happy Racing!
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. WLow performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime
and the nitwits that need headlights for a little rain
If People Drove Any Slower They’d Be Going BackwardsWhen you see fog or “running” lights on in good weather beware. WLow performance driver ahead.
Car: 1991 Bird
Re: i need help with the tbi vss
thank you for the input NINA.....but can you put that to me like a noob. is it the same buffer the car came with? and i had cruise. decided not to have it in the engine bay so i removed it. so can i still use that chip? and where does it go? it WAS a 305. i thought the 5.0 and 5.7 tbis were the same?
TMZIrocZ350
Oct 7, 2015 12:09 PM
