1989 Camaro turn signal/dimmer/cruise control replacement steps needed
Old Feb 28, 2010 | 09:47 AM
patrio61's Avatar
1989 Camaro turn signal/dimmer/cruise control replacement steps needed!! HELP!!
Old Feb 28, 2010 | 09:55 AM
bcmag's Avatar
Re: 1989 Camaro turn signal/dimmer/cruise control replacement steps needed
you need a few special tools. not hard to do but if you have not done before can be a pita.
Old Feb 28, 2010 | 09:58 AM
bcmag's Avatar
is it a straight or tilt column and are you just trying to replace signal lever or actual switch?replacing lever isnt too bad if your sneaky about it
Old Feb 28, 2010 | 10:13 AM
jj74sd455's Avatar
Car: 91 bird
Engine: 305 tbi
Transmission: 4 speed automatic
Axle/Gears: factory
i had to replace the one in my 94,it kinda sucked. i had to pull the steering wheel off (steering wheel removal kit) ,the metal plate behind it (steering wheel hub removal tool), undo and pull the turn signal cam out(dont have to unplug it just let it hang),remove the plastic wire harness cover at the base of column, unscrew the turn signal switch and look at the wire colors,trace em down to the harness and unplug,carefully snake the wire up through the column and out. now reverse process with new part, be patient and take your time-good luck
Old Mar 1, 2010 | 09:51 AM
1988GTA500HP's Avatar
Car: 1988 GTA
Engine: 400 CI
I did this to my son's 88 GTA. All I did was remove the cover from under the dash above the driver''s feet. Disconnected the jack that comes down from the lever. I tied a guitar string to the old lever side harness. I pulled the lever out and carefully pulled the wire up thru the column. I tied the guitar string to the new lever harness and pulled it through the column, plugged it in to the harness, and pushed the new lever into its seat. Took about 20 mins.
Old Mar 8, 2012 | 12:31 PM
Gary Grizzard's Avatar
its a straight column
Old Mar 10, 2012 | 05:27 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
search on youtube "1aauto turn signal" they have a video on how to do it.
Old Mar 10, 2012 | 10:06 PM
Thanks for the information !, Tall Tim
Old Nov 11, 2013 | 09:11 PM
KnuckleDragger's Avatar
Car: 1989 GTA and 1969 Dodge Charger
Engine: 5.7L...blah! It's a 350 baby!!!
Transmission: Automatic
Just bought an '89 GTA. My turn signal stalk is very wobbly. The hi/lo beam function doesn't work. The wipers only work if I push and hold the "washer fluid" tab. Cruise control works just fine.
Would a new turn signal stalk fix my problem, or is it something else?
84z96L31vortec
Aug 20, 2017 12:16 AM
kyleb24
Aug 15, 2015 08:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Rustyweb7
Aug 9, 2015 03:05 AM
antares57
Aug 6, 2015 07:47 AM
