no power to anything need help
Old Feb 28, 2010 | 04:31 PM
my88iroc350's Avatar
i just replaced my cap and rotor today set my timing shut the car off to tighten everything thing up went to start it again and nothing absolutely nothing i got the radio to come on twice but it shut off again starter wont make noise fuel pump doesnt prime fans dont come on nothing i need help i am so confused my dad is very good with electronics so anything you guys tell me to do i can try i tried fusible links they didnt do anything i cant find any blown fuses are there any major fuses or relays that would cause this its a 5.7 350 tpi auto tranny in case that helps
Old Feb 28, 2010 | 04:57 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Re: no power to anything need help
Why did you have to set the timing after a cap and rotor change? Check your battery cables see if they are snug.
Old Feb 28, 2010 | 04:59 PM
because the timing was out why is that an issue
Old Feb 28, 2010 | 05:44 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Not an issue but it sounded like you were just doing some regular service like a cap and rotor and I have never heard of someone having to adjust the timing after doing a cap and rotor swap.
Old Feb 28, 2010 | 05:58 PM
bcmag's Avatar
do you have power to the fuses in the block?check cables and check connection on starter where fuse links originate.with this many things inop shouldnt be hard to find
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
