what is suppost to be here?
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
on the part thats almost directly behind my engine what is suppost to be plugged in there?, and those 3 black boxes, are they hard to replace? the PO left the car in a field and it got a rats nest right infront of those and they chewed some of the wires in half
Engine: L31 350
Re: what is suppost to be here?
bumb, comeon guys i literally have no clue as to what is under the hood so i really need help
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
i'm confused. are you asking for which relays you circled, or are you asking if there's something missing from the pic?
Engine: L31 350
on the three boxes i need to replace the one closest to the fender, but my main question is what plugs into that big black box behind my engine
Engine: L31 350
okay, so what is suppost to plug into the left side of it? i could feel some prongs earlier but i couldnt really see it
Engine: L31 350
i think there is one coming from the lower part, i wouldnt quote me on it because i was more worried about why my car wasnt starting but there isnt anything coming from the top plug
well the first obvious question is if the wipers work... but nothing there will stop the engine from running
Engine: L31 350
well, my stalk is broken so until i get that replaced ill be able to answer that question, now what about those 3 relays? would one of those cause my car not to run?
Car: 1987 camaro rs limited
Engine: 2.8 ltr multiport fuel injected
Transmission: th700r
Axle/Gears: 3.43
when you turn the key can you here the pump run if you can how old is the gas if no fuel pump hum the one of the relays is bad its ether the one by the fender or the one under the other one farthest from the fender
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
The big black box, as previously mentioned is your wiper motor, the prongs you feel on the left side of it, most likely is where your washer pump goes, D*** rats really did a number on you, huh... I'll see if my manual list something for your model...
Axle/Gears: 3.43
and when you replace the realays and still no pump noise replace the fuel pump it will run mine sat for 12 years before i got it in january you can also try hitting the the gas tank to free up the pump but use a hammer and peice of wood so you dont puncture the tank
after this website helped with the troubleshooting the fuel pump issue mine happen to be bad on top of the knuklehead work the po did and a new set of injectors the car runs great
Axle/Gears: 3.43
do you have all of the intake parts there is supposed to be a black box behind the bumper an air tube with two sensurs ones the mass air flow sensure and the other is somthing i have no idea what but its small and has two wires the maf has three wires i belive
Engine: 5.1 4bbl
If I remember correctly the other is an air temp sensor...
Engine: L31 350
my fuel pump turns on when i turn my key on, and the one that has a wire chewed threw is the one closest to the fender, the others looked fine unless they got them down farther
Engine: L31 350
behind the bumber?, im not sure that anythings there but i havent really looked there but ill look tomorrow when i get out of school, where exactly is it behind the bumber?
Engine: L31 350
does anyone know what those other two relays are for?, i know ones for the fuel pump but what about the others?
Engine: L31 350
do you know what order they are in? it would be really helpful
sorry, mine have been jacked around... I unplugged the one that was supposed to be the fuel one, and then I started my car...lol
I'll see if I remember where I saw what it's supposed to be
ok....
from the fender, working your way in...
AC
fan
Fuel
AC
fan
Fuel
Engine: L31 350
okay so my AC is the one that got chewed on,still not good but better because i dont need that at the moment
Engine: L31 350
is that relay an AC connector or an AC compressor control?
Compressor clutch control
Ive seen the relays moved around quite a bit. Check wire colors instead of location to ID the function
AC will be small wires of greens and pink. It will have no red, gray, or large gauge wires
Engine: L31 350
that was the hole i was talking about, the prongs are in there
Wiper motor, it has two connectors, the big one you see there and one small 3 wire connector almost behind the engine. Those are included in the light harness
Engine: L31 350
Engine: L31 350
ok, back on this problem, i got the relay replaced and i found the plug for my wiper moter. but when i turn on my wipers they dont move, i can hear the moter kick on and start to move inside but my wipers do nothing, any tips here?
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Check to see if the wiper arms move at all by hand. It could be that the NYLON drive gear (WTF is it with GM and nylon gears?) in the wiper motor has been wiped out. LOL. Anyways, my ex-brother-in-law and my sister had a problem with this on their second gen Camaro (that I really wish I had right now) and they had to get a new wiper motor.
If the arms don't move, they could be bound up by rust or some other crud hiding in the cowl. Remove the cowl and clean everything nicely (I'm sure there's something in there with as long as the car has sat).
Engine: L31 350
the arms moves if i move it by hand, that mean the nylon gear is gone on this too??
Engine: 2.7L V6
Axle/Gears: 4.41
Probably. Or they could be loose at the drive arm under the cowl screen. There is an arm connected to the motor shaft that connects to the rest of the linkage through 2 screws. Make sure they aren't loose, missing, or stripped. Also make sure that the arm is connected to the motor shaft.
Engine: L31 350
ill look into that tomorrow, it was hard finding that damn plug to begin with
