84 camaro......electric fan controller wiring.
Old Mar 14, 2010 | 06:26 PM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
I have an 84 camaro that has seen a ton of upgrades, the latest of which is an electric fan. So I bought an adjustable fan controller from Derale performance and am ready to install it, the problem is that the instructions call for me to connect the yellow wire to a positive(+) switched ignition source. Is there a power source(switched ignition) under the hood that I can tap into? Or do I need to go to the fuse panel? If the fuse panel is the only option, which spot in the fuse panel would I use?
Thanks a bunch fellas,
onthedownlow
Old Mar 15, 2010 | 08:43 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fanatical Advice
You can connect it to the coil primary 12V input, however use a relay.
Happy Racing!
Round Out Your Life, Drive Oval Tracks
Old Mar 15, 2010 | 12:59 PM
Engine: 355
Re: Fanatical Advice
what fuse spot would I use for this?
Old Mar 15, 2010 | 02:06 PM
NINÅ's Avatar
Transmission: 765R4
Fanatical Advice
That car might have an empty space where the FAN fuse would be with certain engine options.
Use a 30 amp fuse unless the manufacturer recommended otherwise.
Anyway you want to use a hot in RUN wire from the fuse block.
It’s a
12 AWG orange wire.
Happy Racing!
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
MSRed91Camaro
Oct 6, 2015 01:56 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
