dome light wiring
Car: 86 camaro
Engine: strong 350
Transmission: stage3 700r4
dome light wiring
i am tring to wire the dome light in my 86 camaro and i have a aftermarket wiring harness that has a white wire for the dome light. i still have the door switch and the plug for the dome piece. i still have part of the white and orange wire for both. how would i wire this up as well as tying in the light switch in to it.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Look Into The Light
Does the new dome light have a switch on it?
If yes, do you want to use that switch instead of the one on the headlight switch?
Happy Racing!
Happy Racing!
Round Out Your Life, Drive Oval Tracks
Car: 86 camaro
Engine: strong 350
Re: Look Into The Light
i still have the stock dome light and the switch that is for the door i was just wondering how to hook both the door switch and the head light switch up with the one wire i got with the harness
Transmission: 765R4
Look Into The Light
You can connect the new white wire to the ground common point of the door switches - “courtesy” - map light.
Those wires are white.
With an ohmmeter you can verify the factory connections are intact.
Happy Racing!
Happy Racing!
Car: 86 camaro
Engine: strong 350
Re: dome light wiring
so i would hook up to the my wire from the harness to the orange wire of the door switch and would i do the same for the white wire of of the headlight switch
ambainb
Apr 25, 2016 09:21 PM
