1984 Trans Am Headlight/Relay Information
Old Mar 15, 2010 | 11:34 AM
cxxm's Avatar
Car: 1984 Trans Am
Engine: 305 L69 (E4ME)
Transmission: NWC T5 1352-072
Axle/Gears: 3.73 (6HS)
Just information for anyone who needs it.
This year uses three different relays to operate the headlights:
(One) Isolation Relay #10022620 (I found this in between the radiator and battery)
1984 Trans Am Headlight/Relay Information-battery-10022620.jpg
(Two) Headlight Actuator Relays #10031246 (I found one on the LH fender near headlight and the other on the RH fender near headlight and battery.)
1984 Trans Am Headlight/Relay Information-driver-56-1793.jpg
1984 Trans Am Headlight/Relay Information-passenger-56-1793.jpg
All of these relays have “HR” on the top and 10031246 cannot replace 10022620.
GM dealers show that 10022620 relays are discontinued and 10031018 relays are a replacement for all the relays. As far as I can tell, 10031018 is a replacement for 10031246 Actuator Relay, but cannot be used for the 10022620 isolation relay. I do not believe there is a replacement made for 10022620 and I notified GM about this possibly being wrong in their parts catalog. GM sells 10031018 for $50 and I did not want to spend the money to find out.
Car Quest sells a replacement for 10031246 for around $22. The part number is 56-1793. The only replacement 10022620 I could find is on other Firebirds and Fieros around the same years. Just look for the 10022620.
Links about 10022620 relay:
https://www.thirdgen.org/forums/elec...em-solved.html
https://www.thirdgen.org/forums/elec...-trans-am.html
https://www.thirdgen.org/forums/exte...headlight.html
https://www.thirdgen.org/forums/elec...ay-1986-a.html
How to test circuits: Go to You Tube, search “fiero gen 1 headlight motor circuit test 1of2”. Buddy Craig has two great videos on how to do this using a testlight and manually crossing wires to figure out what is and is not working.
How to rebuild the headlight motors: Go to You Tube, search “Rebuild of Fiero Gen 1 headlight motor”. There are seven videos by Buddy Craig, who does a great job on how to rebuild the motors.
Firebird Headlight Rebuild Parts: Check out www.rodneydickman.com/retail.html. Rodney specializes in Fieros, but also does the Firebirds. Most motors seem to have just the one plastic gear that strip, but mine had two plastic gears. The Intermediate gear was plastic in my headlight motor and the one that was broken. Rodney hooked me up with a metal one and provides complete instructions on how to perform the rebuild.
Here’s the numbers off my motors in case it is helpful:
Passenger headlight motor (not going up, but will go down. Has plastic intermediate gear): # 5048?01 Delco Products 224 5 17 11
Driver Headlight motor (works): #5045724 Delco Products 170 5 17 11
Good Luck…
Old Jul 29, 2010 | 04:42 PM
cxxm's Avatar
Car: 1984 Trans Am
Re: 1984 Trans Am Headlight/Relay Information
Pictures of headlight motor
1984 Trans Am Headlight/Relay Information-motor1.jpg
1984 Trans Am Headlight/Relay Information-motor2.jpg
Link to another headlight problem I posted.
https://www.thirdgen.org/forums/elec...ml#post5554455
Old Nov 3, 2010 | 08:51 PM
3rdgenfever's Avatar
Car: 89 IROC-Z & 92 RS
Engine: 350 TPI & LQ4 408 in the works
Transmission: 700R4 & T-56
Axle/Gears: stock/ LT1 disc 3.42
yeah i went through the same crap going back and forth with my local GM dealer to find out the same info on the part numbers. Nobody makes this relay aftermarket at all, looked everywhere. The problem is the actuator relays are used for a ton of other applications that's why they still make them. The isolation relay configuration as no use for anything else so they stopped making them. Sucks, had to call a scrapyard. Really thinking about buying up all the used isolation relays i can find, then i can charge whatever i want for them.
Old Nov 7, 2010 | 10:41 PM
cxxm's Avatar
Car: 1984 Trans Am
I have had pretty good luck finding them in Fieros. Picked up a couple for the future...
Old Jun 4, 2015 | 02:41 PM
katana247's Avatar
1986 Trans Am Headlight/Isolation Relay Information
bwd makes Isolation Relay to the headlights, see link below. It is not name Isolation relay.
BWD RELAY R6433 cost 72.99. expensive but its a direct fit.
http://shop.advanceautoparts.com/p/c...6-P#fragment-3
Old Sep 9, 2017 | 01:19 PM
unionbill's Avatar
Car: 1986 Trans Am
Transmission: Automatic
Axle/Gears: 2.77
So years later I am in the need for the Isolation relay. I imagine I'm not alone. It appears there is no option from the my local Gm dealership, Advanced Auto or anywhere on the internet for the GM 10022620 or BWD R6433. Does anyone have any options?
Old Sep 9, 2017 | 03:52 PM
unionbill's Avatar
Car: 1986 Trans Am
Axle/Gears: 2.77
Well this is about the best I have found lately! http://www.rodneydickman.com/catalog/index.php
Old Sep 9, 2017 | 08:52 PM
NoEmissions84TA's Avatar
So these would all be actuator relays?
Or is the RY130 the isolation relay?
Attached Thumbnails 1984 Trans Am Headlight/Relay Information-headlight-relays.png
Old Sep 9, 2017 | 09:36 PM
T/ATiger's Avatar
RY130 relay is the motor relays and not the isolation relay. P/n 10022620 is the isolation relay but good look finding one or a replacement. I built a isolation relay (DPDT) and haven't had any trouble yet i wish you luck.
Old Sep 9, 2017 | 09:52 PM
unionbill's Avatar
Car: 1986 Trans Am
Axle/Gears: 2.77
Yes I believe so. The Isolation relay is internally different. So it would not be listed as a actuator relay also. It is quite unique.
Old Sep 10, 2017 | 07:24 PM
So is the isolation relay just a DPDT relay, or is it something unique?
I found this and was wondering if this could be exactly what we all need:
https://www.northerntool.com/shop/to...iABEgLSvvD_BwE
https://www.northerntool.com/images/...arts/27328.pdf
https://www.northerntool.com/images/...uals/27328.pdf
The thing that bothers me about this is the specs say MAXIMUM ON TIME = 15 minutes.
Can someone post the schematic of the isolation relay? I want to figure this out.
I assume that 12vdc gets applied in 1 direction to raise the headlights, and then gets reversed
to lower them???
Old Sep 10, 2017 | 09:21 PM
unionbill's Avatar
Car: 1986 Trans Am
Axle/Gears: 2.77
Without looking at the wiring schematic in the service manual, I can't say for sure. But it looks similar. It could be cheaper. Has anyone tried Rodney Dickman's set up?
Old Sep 10, 2017 | 09:22 PM
T/ATiger's Avatar
to lower them???
It is a DPDT relay but not any one will work. I work in aviation and was able to figure out how to make one. Check this site out, he has made one that just splices in. rodneydickman.com/catalog/product_info.php?cPath=47&products_id=422. It's $36.95. I haven't used his and know nothing about him, but I hope it works. Nearly impossible tongind one. Good luck
Old Sep 10, 2017 | 09:24 PM
T/ATiger's Avatar
Originally Posted by T/ATiger
It is a DPDT relay but not any one will work. I work in aviation and was able to figure out how to make one. Check this site out, he has made one that just splices in. rodneydickman.com/catalog/product_info.php?cPath=47&products_id=422. It's $36.95. I haven't used his and know nothing about him, but I hope it works. Nearly impossible to find one. Good luck
Also, do you have any used ones that don't work? They can usually be fixed.
Old Sep 10, 2017 | 10:18 PM
T/ATiger's Avatar
This is a schematic of the headlight system. Isolation relay is marked
Old Sep 11, 2017 | 01:18 AM
I'm going to have to investigate this more.
But it seems that Rodney Dickman (tell me he didn't get picked on in school with that name) has already solved the problem.
Old Sep 11, 2017 | 06:46 AM
T/ATiger's Avatar
Not sure but I like to stay as stock as possible! Good luck.
Old Feb 24, 2024 | 03:39 PM
1985blktransam's Avatar
Car: 1985 Firebird Trans Am
Engine: 5.0 Liter Engine
Axle/Gears: 3.08
Hi:
Is this still valid for the Headlight Relay Replacement for GM Relay 10031246:
Car Quest sells a replacement for 10031246for around $22. The part number is 56-1793
For a 1985 Trans Am
Old Mar 29, 2024 | 11:38 PM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
only place i've actually found the isolation relay for sale
https://www.lectriclimited.com/vehic...del/58?cat=734
Old Apr 5, 2024 | 02:26 PM
icedog11's Avatar
Car: 1986 Firebird Trans Am
Engine: LB9 305 TPI
Axle/Gears: Borg Warner 9-Bolt 2.77"
If you've tried this one, does it work? I've been trying to find one for a few months now, and I've made the mistake of trying 3 of the actuator relays on accident.
Old Apr 17, 2024 | 01:38 PM
kmcn47's Avatar
Transmission: 5spd
not only is it the exact relay for our cars it also comes with the mounting bracket attached, and yes it did fix my problems
but they do, the link i provided is THE isolation relay and its only like $50 bucks
Old Apr 17, 2024 | 01:57 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I bought this for my 84 works great
https://rodneydickman.com/product_in...roducts_id=418
86Firebird860
Oct 17, 2014 07:47 AM
sflthndrckn
Jan 3, 2010 07:20 AM
YoungMoneyVII
Jun 29, 2009 09:31 AM
