everything is dead!
Old Mar 16, 2010 | 06:11 AM
timatom's Avatar
everything is dead!
hey i just picked up a 91 firebird that is in great condition for $300!!! the only thing that i can find wrong with it is the electronics don't work. the dome light wont come on, dash lights, head lights wont flip up or come on, the radio, basically what ever has to deal with lights will not work! lol
any main spots i can check. i looked at the fuses and i didn't see anything?
Old Mar 16, 2010 | 08:49 AM
richy87mintiroc's Avatar
Car: 1991 Z28
Transmission: AT
Axle/Gears: Stock
Re: everything is dead!
Does it start up or does nothing when you turn the key over?
Old Mar 16, 2010 | 09:12 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Wire Mire
Remove and clean all wires going to the starter solenoid.
Happy Racing!
If We Don’t Get Cawt We Ain’t Cheatin
Old Mar 16, 2010 | 02:58 PM
timatom's Avatar
no it starts and everything... i ordered a new head light switch but i dought it is the problem
Old Mar 16, 2010 | 03:02 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
the first time I looked at my car before I bought it, it was doing exactly what you described. The guy who owned it worked on it, said he fixed something with the headlight switch, and it has been fine from then on.
I can't swear he replaced the switch, but if not, it was something related to the switch
Old Mar 17, 2010 | 07:48 PM
timatom's Avatar
ok so i been working on it for like 5+ hours already!
i bought one of them screw driver that light up when you put it on a hot wire.
all the fuses are good(tested all of them). the wires that go into the box for the switch that plugs in the wires that are supposed to be hot arnt?
i need to figure this out. if any one has suggestion i appreciate it cuz im out.
just turned 16 got my license and haven't gotten to drive yet!
Old Mar 17, 2010 | 09:42 PM
irock88's Avatar
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
sounds like a switch problem,you checked continunity for the fuses so theyre good have you checked power at the- light- fuse location and if thats good,fuses are good and you still have no power at the switch plug it might be a bad wire connection at the fuse block,or bad wire
skinny z
Carburetors
Sep 29, 2015 11:25 PM
92projectcamaro
Sep 29, 2015 07:07 PM
raymondandretti
Sep 27, 2015 06:43 PM
Jonas Earl
Sep 27, 2015 07:39 AM
Johnoooooo
Sep 22, 2015 08:55 AM
