simple ?
Old Mar 18, 2010 | 08:58 PM
87firebird305V8's Avatar
Car: 87 firebird
Engine: carbed 305
simple ?
Ok, my horn just stopped working one day. i sorta need it for my inspection wensday. so i figured it was the fuse. i looked under my dash and nothing really pops out as the horn fuse. so i was wondering what does the horn fuse say or look like what size is it. or am i just stupid and it is a obvious fuse.
Old Mar 18, 2010 | 11:32 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: simple ?
Hello 87firebird305V8!!
The fuse that powers the horn is the 20 Amp ACC Fuse, there is also a "convienience center" under the dash that has the horn relay!!
Sometimes, the horn just craps out!!
Hook up a test light to the electrical connector, at the horn and push the horn button, look for the light to come on!! No light, no power!! Three possibilities, 1) Fuse, 2) Horn Relay, 3) Short in wiring/broken wire/bad ground!!
Good Luck!!
Old Mar 19, 2010 | 01:26 AM
91V6firechicken's Avatar
Re: simple ?
Good Luck!!
or #4 bad button,
#5 whats that called in the steering wheel for the horn connection and what not....the little disk
Old Mar 20, 2010 | 01:43 AM
Re: simple ?
Originally Posted by 91V6firechicken
or #4 bad button,
Hello 91V6firechicken!!
I think #3 covered #4, and #5!!
Thanks any ways!!
wigmobile
Feb 26, 2025 02:56 PM
Pac J
May 17, 2020 10:44 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
mfp189
Sep 27, 2015 09:25 AM
CatmanFS
Sep 19, 2015 09:00 AM
