Horn problem
Old Mar 19, 2010 | 11:09 AM
jim_diesel_2000's Avatar
Car: 91 Z28
Engine: 350 sbc 40 over 357?
Horn problem
Previous owner took the wire off the horn. I put it back on to find (as i figured), that the horn was on constantly. Pulled the airbag to look around and found one of the wires was bare against the airbag screw. I need a horn to pass inspection, so I cut the wire and attached it to a push button switch for now. After I did that, now the horn goes off constantly only when i open the door. Is the horn relay and the door switch tied in somewhere? The schematics I have don't cover the horn.
Old Mar 19, 2010 | 12:03 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Horn Scorn
Maybe the PO rigged an alarm system.
Anyway the negative side of the horn relay is being grounded when you open the door.
Get to the relay and find where the PO mod is and remove that connection.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
