Shift light + buzzer
Old Mar 25, 2010 | 11:21 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
I just finished wiring up my custom dash panel, including a shift light. However, I also want to wire up a buzzer to go along with the shift light, so that the buzzer will go off if I go too far over my target RPM's.
Would this be possible to do?
Could I somehow take a "pill" http://www.summitracing.com/parts/ATM-5356/ and use it to wire up a buzzer to come on at a specific RPM?
Old Mar 25, 2010 | 11:35 AM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
Re: Shift light + buzzer
why? what you you tell a hot chick riding with you when the buzzer goes off. i think it'd be pretty obvious if you were redlining the motor. the light should do the trick, especially if you got the led lights
Old Mar 25, 2010 | 01:05 PM
I'm not sure how "obvious" it's going to be when the light goes off. I'm sure I'll have no problem seeing it at night, but I'm not sure about during the day. That's the reason behind it
Mine doesn't have an LED, it's just a single bulb. If I knew what bulb to replace it with I'd definitely do that
Old Mar 25, 2010 | 02:01 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Tuff Pill To Swallow
The pill contains a resistor.
It won’t do anything by itself.
You can wire on op-amp to the shift light in the dash, and have the op-amp operate a buzzer.
Happy Racing!
“Just One Of Them Racin’ Deals”
LittleFranks
Sep 17, 2015 12:22 PM
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
