how hard is it to change fog light bulb on a 91 TA ?
Old Mar 29, 2010 | 02:30 PM
stan12777's Avatar
Any ideas? do i get to it from underneath the car or on top? and do i need to take out the whole housing for that? thanks guys
Old Mar 29, 2010 | 02:41 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: how hard is it to change fog light bulb on a 91 TA ?
Hello stan12777!!
On my IROC, it's from underneath, 1/4 turn, and it's out!!
Be careful of the bulb, it's a halogen, and can shatter in your face, while working that close to it!!! (assuming that your crawling under the car, on your back)
I know your asking for a 91 TA, but it should be the same, or very close to it!!
On a fourth gen Camaro it's a real PITA!!!
Old Mar 29, 2010 | 02:53 PM
my82roc's Avatar
Car: 89 Iroc Convertible
The T/A fog light bulbs are held in place by a thin wire clip that sits in a groove.You have to squeeze both ends,remove the clip and then the bulb will be accessable.I think it would be easiest to do by removing the fog light first only because of the way the clip has to be attached
Old Mar 29, 2010 | 07:12 PM
stan12777's Avatar
ok great, thank you guys very much...
jaridjohn
Jul 8, 2024 03:49 PM
maroe624
Apr 16, 2017 08:29 AM
Fronzizzle
Aug 19, 2015 01:36 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
