turn signal wiring diagram
Old Mar 29, 2010 | 02:47 PM
IROC Skillz's Avatar
Does anybody have a wiring diagram for the entire turn signal circuit? I have an 87 Camaro, tried removing a lot of excess wires when I had the dash out and removed too much. Now I have to figure out what I accidently cut. Any help would be appreciated. Thanks.
Old Mar 29, 2010 | 05:46 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Re: turn signal wiring diagram
will this help you ?
Old Mar 29, 2010 | 11:08 PM
That'll do it. Thanks for your help
Old Sep 2, 2012 | 09:38 AM
napalm368's Avatar
Car: 1986 iroc z28
Transmission: 700-r4
Hi. i need a little help. my left turn signal bulb in my cluster works and will flash,,but my right does not.(the turn signals still work on the outside of the car on both sides) its just that my bulb on the right in my cluster will not flash...(i tried replacing the bulb) I need to know wich wire runs the right side,,so i can see if it is at least getting power...and try to figure out a fix for this. im not great at looking at diagrams....but am i correct in assuming that the wire is dark green for the right side? thanks for any help.and also...would the wire be located on the steering column ? or elswhere?
Old Sep 2, 2012 | 10:12 AM
1988GTA500HP's Avatar
Car: 1988 GTA
Engine: 400 CI
Looks like from the diagram it would be dark blue.
Old Sep 2, 2012 | 10:21 AM
napalm368's Avatar
Car: 1986 iroc z28
okay..i see now. thanks. ill give it a shot.
Old Jun 4, 2017 | 01:14 PM
zaxanllc's Avatar
Car: 86 Firebird TA
Transmission: Automatic
Axle/Gears: Stock POSI
Can someone please repost the diagram the link is bad from the old one.
Fronzizzle
Mar 18, 2019 08:29 PM
Caspar
Jun 19, 2016 11:19 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
