brake lights
brake lights
He Everyone!!
I finally got around to taking the camaro apart and getng some paint thrown on it. When I put it ack together, suddenly my brake lights didn't work anymore. The running lights works and the turn signals work, but when I push the pedal nothing happens. Then, when the car is turned off, I push the brake pedal and all the running lights come on including the dash lights and it beeps as if the lights were left on without the key.
Any suggestions? I double checked the bulbs to make sre a single filiment wasn't in the place of doube and so forth, but it was late last night and that is all the further I got into the diagnostic.
The car is a 87 z28...5 speed manual...electic hatch
Thanks!!
Thanks!!
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: brake lights
Sounds like you're getting battery to ground. Did you re-wire anything?
Re: brake lights
I didn't rewire anything...I'm thinking that during the disassembly I must have pulled a wire unintentionally...I found 3 wires around the electronic hatch unit that are not connected...I don't know where they are supposed to go, or what they are supposed to do.
Re: brake lights
so I found out now after looking at it during the day time that I didn't hook up my third brake light...so now all blinkers and runn lights work, but the brake lights fail. and it still beeps and turns on the running lights when push the brakes without the car on. hahaha
Re: brake lights
so I went through and checked the bulbs...I believe I have the single/dual filament part correct...as I was looking at the plugs I noticed a pretty large amount of gunk in the bottom of the plugs? Is this a contact enhancer or something? It looks like it was purposefully put there?
