problem help??
Old Mar 31, 2010 | 11:42 AM
COTY'S IROC-Z's Avatar
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
problem help??
i took my speedometer out an then 1 day lader i put it back in know when i turn my turn signal's on they don't blink they stay on soild???? help? inty one lol
Old Mar 31, 2010 | 02:25 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
I Can Blink, Therefore I Can Speed
There’s no way to know from here what you might have touched.
Turn the key to the RUN position.
Turn the signal stalk to the left turn position.
If your left and right have the same problem, connect a voltmeter to the
light blue wire at the connector on the lower right side of the steering column.
(It’s the longer-flat nearer to you of the 2 connectors in that area.)
Is there power there?
Now measure the
dark green wire in the same connector.
Happy Racing!
“After The Fourth Barrel Roll I Lost Control Of The Car”
Old Mar 31, 2010 | 03:30 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: problem help??
Did you reseat the cluster properly--and tighten the two 10mm nuts?
JamesC
Old Apr 4, 2010 | 10:46 PM
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
Re: problem help??
i got it fixed it was a low battery problem.....lol
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
