VATs interfering with spark?
Old Apr 1, 2010 | 04:04 PM
NoCal91Convert's Avatar
Car: 1991 Z28 Convertible
Transmission: 5 Speed
Lost spark, checked coil, changed ICM, checked distributor, seems it is nothing mechanical. The suggestion is that the VATs may be acting up. If so, will getting a chip burned that bypasses VATS solve that problem?
Old Apr 1, 2010 | 04:15 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Re: VATs interfering with spark?
Go to this page : http://www.vatssucks.com/
There you have guides to completly remove VATS from your system.
There could be a bad ignition module or the blastercoil thats not working as it should to.. check the ignition module in your distributor.. also, is your battery 100% fully charged, try charging it over night and see if it gets better..
Old Apr 2, 2010 | 12:46 PM
Will look at it. Not being into redoing the electrical, I was hoping the chip would accomplish the same thing. Thanks for the heads up on that site.
Old Apr 2, 2010 | 04:57 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If the car even tries to start (starter working), then it's NOT VATS. VATS disables total start function.
Old Apr 2, 2010 | 05:11 PM
Theking's Avatar
Car: 1989 IROC-Z
btw, your SECURITY light does that shutdown after some seconds or does it stay ON all the time ? Cause if VATS is working properly it will turn off the SECURITY light in your dash (when correct key is inserted) if it stays on, VATS is failing.
Old Apr 2, 2010 | 07:42 PM
The car turns over, so must be something other than VATS. I will recheck the ignition parts.
Old Apr 3, 2010 | 08:10 AM
Theking's Avatar
Car: 1989 IROC-Z
Engine Cranks But Will NOT Run (TPI) : http://theking.joakimweb.se/z28/tech...t_wont_Run.zip
Engine Cranks But Will NOT Run (TBI) : http://theking.joakimweb.se/z28/tech...t_wont_Run.zip
Download the correct .zip file for your engine, and test it.
There you can rule out different things, Go thru the guides (4 pages) and test and get back here with results (files are on my homepage http://irocz.info.se/ if you want have a look at it, much about 3gen cars etc, pictures, carshows and more)
RS Reaper
Oct 17, 2018 07:52 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
