Blower relay on non ac?
Old Apr 9, 2010 | 12:00 PM
racer7x's Avatar
Car: 85 TA
Did the factory non ac cars use a relay for the heater blower or is it run direct from the switch?
Guess I am wondering if I can eliminate the relay after ac delete conversion. I have the non ac wiring and doesn't appear to have used a relay.
Old Apr 12, 2010 | 11:19 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Relay Race
They ran it from the switch.
You can eliminate the relay however GM might have used a lower current rated speed switch for the HEATER ONLY models due to the fact the relay draws only a tiny fraction of the current, therefore you might burnout the switch.
Also, 16 AWG wire is used verses 14 AWG, therefore the hi speed might run a bit slower due to voltage drop.
Happy Racing!
I’ve NEVER Hit The Wall - (The Safer Barrier Prevented It)
Old Apr 27, 2010 | 07:47 AM
racer7x's Avatar
Car: 85 TA
Re: Relay Race
After closer inspection it looks to me like the relay only powers the blower at the HIGH switch position on AC models.
Old Apr 27, 2010 | 08:02 AM
NINÅ's Avatar
Transmission: 765R4
Relay Race
This is true.
That’s where the max current draw is.
Happy Racing!
Make Noise, Turn Left, Repeat
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
buckeyecelt
Sep 24, 2015 05:50 AM
