Starter Wiring
Old Apr 11, 2010 | 08:49 PM
Whoboy580's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Transmission: Powerglide
Axle/Gears: 4.10
Starter Wiring
I have a 1986 Camaro which was a 305 carb, I just put in a 383 stroker and I relocated my battery to the rear of the car and i am wondering if anyone could help me. I have one small blackish color wire i knows goes to the starter than i have another wire the has two wires the connect and make one wire I know that goes to the starter. Now here my question do i connect the battery wire that comes straight from the battery to the starter or no?
Old Apr 13, 2010 | 02:48 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: Starter Wiring
you still connect the batter to the post on the start. The other wires, assuming they haven't been molested, should be the fusible links for main feed on the bulkhead connector and the blackish was probably purple a long time ago and is your starter enable wire (solenoid).
Old Apr 13, 2010 | 02:50 PM
1981LT1's Avatar
Engine: LT1; LT1
Re: Starter Wiring
you also need to make sure the charge wire on the back of the alternator is attached to the starter. Without this your car will not charge and you will have a dead battery within a couple of days.
Old Apr 13, 2010 | 06:30 PM
Whoboy580's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Axle/Gears: 4.10
Re: Starter Wiring
ok thank you soo much and yes the black one still has a purple look to it lol. Yes those two wire the go to one still have the fuse and no cuts or anything. Thanks again.
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
Accerrito22
Aug 23, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
