radio one side not working
Old Apr 21, 2010 | 10:42 AM
jordanandrewkay's Avatar
Car: 1991 T/A GTA H/T
Axle/Gears: 3.23 Posi
okay i have a 91 gta and a cassette with equilizer the right(passenger) side does not have sound. but if i put the sound all the way to that side all four work at same volume level. but drastically lower in volume. short? or is the radio just bad.......any help would be badass. im tryin to keep the car the way it was off the lot..
Old Apr 21, 2010 | 03:26 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Hello Radio
Look behind the radio and make sure there’s no wire rub-thru after all these years, and make sure the connectors pin are clean.
If all the connections are in good shape the problem is internal.
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Old Apr 21, 2010 | 06:05 PM
Re: radio one side not working
well i did pull it out probably a month ago the wires actually looked alot better than i thought they would. but im gonna break down the harness more to check it out thouroughly. i did not even think to check the pin connections. thx for the input.
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
