bright lights(high beams)
Old Apr 21, 2010 | 10:36 AM
jordanandrewkay's Avatar
Car: 1991 T/A GTA H/T
Axle/Gears: 3.23 Posi
okay check it out i have never been in another camaro or firebird so im a lil unfamiliar with these cars....the bright light switch should be on the signal light and windsheild wiper stock right???? i pull mine back....no click ....no high beams...just wondering what you guys think.
Old Apr 21, 2010 | 01:51 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Bright Idea
The high beam switch might need adjusting.
You can gain access to it at the bottom of the steering column.
When you pull the lever you'll see the moving rod and the switch.
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Old Apr 21, 2010 | 06:15 PM
Re: bright lights(high beams)
bada**. ima check that out right now
GTAman
Mar 15, 2019 11:40 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Omega
Aug 10, 2015 12:46 PM
