Rear hatch motor stuck down
Old 04-21-2010, 05:29 PM
shovelbum87's Avatar
Car: 1986 Camaro
To make a long story short, Last winter I took the battery out of my 86 camaro and stored it outside. This spring I removed the car cover and used my key to open the rear hatch to stow the cover. When I replaced the battery the motor on the rear hatch did not go up. It is stuck down, I have tried to use the switch to release it and that does not work, there is power coming out of the switch. the key will not make it pop. Nothing is working.
I have had the interior out chasing the red/white wire which feeds the power I see no problems there. The "actuator" I will call it on the deck lit itself seems to be fine it has good ground I am at a loss If anyone could help I would GREATLY appreciate it.
Old 04-21-2010, 06:05 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Rear hatch motor stuck down
Stick your finger in between the brushes and touch the switch to bring the latch up. Don't worry nothing going to grab your finger.
Old 04-21-2010, 06:40 PM
serpentracer's Avatar
mine started to get stuck every now and then. I had to tap on the motor or the metal part of the latch with something and it would work again.
Old 04-22-2010, 07:22 AM
Car: 1986 Camaro
Thanks, I wasnt sure if that would work with the latch down I thought it only worked to make it go down.
I will def. try this!!
Thank you so much
Old 04-24-2010, 09:20 AM
Car: 1986 Camaro
Well, the switch did not work, but I did find that the relay in the console is junk!
Old 05-01-2010, 01:52 PM
Car: 1986 Camaro
the relay did make the release button work but the motor still will not move, I was looking in the gm service manual and it said that there was an in line fuse between the ignition switch and the motor on a red only wire before it turns to a red and white does anyone know where that would be located??
Vintageracer
01-10-2020 05:33 PM
madsv1000
08-20-2015 06:45 AM
stalkier
08-13-2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
08-08-2015 11:48 AM
z28addict8490
08-07-2015 08:48 PM
Quick Reply: Rear hatch motor stuck down
